Ansys Learning Forum Forums Discuss Simulation Fluids Clarifications on Site Species and Porous Zone Material Reply To: Clarifications on Site Species and Porous Zone Material
sudeepns.197me025
Good Morning Sir,
Thank you for the reply.
As per your suggestions, I created Ni_Site in the Create/Edit Section under materials for surface reaction and chose Ni in the Porous zone drop-down list by giving the same property as Ni_Site to the Nickel in the porous zone.
However, I come across the following difficulties.
1. I was not able to choose the 'Non-equilibrium' in the porous zone. It was greyed. Hence, I was not able to enter the interfacial area density and Convective heat transfer values.
2. However, I continued with Equilibrium conditions in a porous zone, and I first used the volumetric reaction and then the surface reaction. Whenever I use the surface reaction condition, '#f1 error' gets displayed on the screen, and fluent exits automatically.
Looking forward to your suggestions to get rid of this problem.
thank you.Â
