Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Diametrical compression simulation › Reply To: Diametrical compression simulation
October 14, 2024 at 9:17 am
Hey,
Check out this APDL verification which has the setup of Diametral Compression of a Disk
https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/ans_vm/Hlp_V_VM141.html
Here is the input for the sameÂ
https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/ans_vm/Hlp_V_VM141TXT.html
If you don't have much experiece in Ansys APDL, Here is how to approach the problem
You can also try using a quarter symmetry to help in reducing simulation time.
Let me know how it works out.
Thanks
