Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Resolution Bezier object › Reply To: Resolution Bezier object
chrsa
Dear Guilin,
sure I could use a ring object for a ring, but sadly the ring object does not provide any non 90 degree sidewall angle. Regadring the Bezier - I also belive it should be smoth but somehow it is not for big objects.
Do you have any other suggestions? I assume I could use a polygon and extrude it along a circular path. But is there any simpler solution than that?
Christian
