Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › How to select half a body after section view › Reply To: How to select half a body after section view
October 14, 2024 at 6:45 am
I'm not sure I understand your question correctly, but if you are looking to select half of the body, you will need to split the body using the Split body tool and the section plane.
