Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Error: An error occurred when post processor attempted to load a specific result › Reply To: Error: An error occurred when post processor attempted to load a specific result
bram.dupre
Update 2
During the testing of LS-DYNA in Mechanical, the student version of the solver just disapeared and I can’t select it anymore. When I change the XML file to add other solvers, I can select these but they don’t work (error).
In short, now I can see all defined solvers (including updates of XML) except for the student version. For any solver I select I get this error (same error as no solvers where defined at all):
The current XML (changed after the LS-DYNA student version disapeared):
LS-RUN
If I try to run the solvers via LS-RUN this is the output:
Student version (this one solves normal):
R14.1:
R15.0.2:
For the non-student version, note the license error. I don’t have a license for that, which could explain why it doesn’t solve.
For all 14.1 versions, Windows 8/10 is supported.
For 15.0.2 only Windows 10 is supported.
Does that mean Windows 11 isn’t supported at all?
Kind regards,
Bram Dupré
