Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software Error: An error occurred when post processor attempted to load a specific result Reply To: Error: An error occurred when post processor attempted to load a specific result
bram.dupre
Hi Reno,
Thank you for your feedback.
For the second URL I need to log in using my “Account Number/Customer Number” (Ansys Customer Support Space Registration Form). But I don’t have one, I guess, because I am a student.
Without the procedure I managed to change the XML (note I downloaded and installed both single and double precision version) and the following errors pop up:
Mechanical:
The test setup is a destructive tensile test.
Workbench:
One of the two maps (see XML for path)
I also tried using the ansyscl.exe for both filenames in the XML, but I beleive ls-dyna_smp_s_R15.0.2_1-g1e7cfa42b1_winx64_ifort190 and ls-dyna_smp_d_R15.0.2_1-g1e7cfa42b1_winx64_ifort190 are the actual solver file.
As you could reproduce the error of LS-DYNA, you might be able to reproduce the error of the Explicit Dynamics solution too (YT-tutorial). In that case I am sure I don’t have to look any further into the issue because I can’t solve it myself.
These are my findings so far. I will experiment further with the settings tomorrow.
Kind regards,
Bram
