Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Calculating heat generation profile in FDTD using narrow band CW sources › Reply To: Calculating heat generation profile in FDTD using narrow band CW sources
Guilin Sun
You can use symmetry BCs in FDTD, and the result in the analysis group will automatically unfold it to normal periodic unit cell. HEAT has isulating BC that you can use on the symmetry BC.
