Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Workbench LS-Dyna solver severe (157) error › Reply To: Workbench LS-Dyna solver severe (157) error
October 11, 2024 at 6:19 pm
UPD: problem solved
The reason why the error occurs is the incorrect default contact formulation in the Body interaction object. This is solved by using the Contact Properties object to change the formulation to General (AUTOMATIC_GENERAL)
.... but it took a lot of time to find the solution using the try-and-fail method(
