Ansys Learning Forum Forums Discuss Simulation Photonics Calculating heat generation profile in FDTD using narrow band CW sources Reply To: Calculating heat generation profile in FDTD using narrow band CW sources
Guilin Sun
I am not sure which tool/example you are referring to? FDTD can have symmetry BCs for sure. Please check if FDTD is controlled by script in "model" or "analysis group". If it is controlled by script, you can set the symmetry BC there.
HEAT solver by default has insulation boundary, meaning without heat exchange on the default BCs.
Please write new post for any questions not directly related to the topic.
