Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Multi Ring Resonator Simulation Hardware Requirements › Reply To: Multi Ring Resonator Simulation Hardware Requirements
October 11, 2024 at 4:42 pm
There are a few WDM examples online, using INTERCONNECT. Please search AnsysOPtics with term "wdm" and find proper examples for you to refer to.
If you want to use FDTD to simulate such device, it will need a lot of memory becuase each is more then 400um, and long simulation time, since it has different resonance. You can try to set them in FDTD and do memory check without running. Never hit "run" button in such case otherwise your computer may freeze without response.
