Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Solution processing not proceeding further › Reply To: Solution processing not proceeding further
rani.a
Hi Erik,
Sure, i will try out a sample model for both static structural and modal analysis and get back.
Meanwhile, you had mentioned about 1E-6Hz being very low. Was it the values on the RHS your were referring to? If so, they are the mass values, not frequency. Probably the mass of nuts & washers in the assembly.
