Ansys Learning Forum › Forums › Discuss Simulation › Fluids › What is the difference between total heat transfer rate and total surface heat f › Reply To: What is the difference between total heat transfer rate and total surface heat f
The clue is in the definition: WALL function. There's no flow through a wall.
