Ansys Learning Forum Forums Discuss Simulation General Mechanical Solution processing not proceeding further Reply To: Solution processing not proceeding further
erik.kostson
Hi
First run a simple analysis on a steel cube/beam just to check that all is ok.
Not sure, but you seem to have lots of very low freq. (1E-6 Hz)? if that is the case it will be a huge amount of modes untill 7 Hz if they are so low - check material, contacts, constraints, properties etc.
All the best
Erik
