Ansys Learning Forum Forums Discuss Simulation Electronics Do I need to use core loss? Reply To: Do I need to use core loss?
Timos
Hi, you can apply an AC voltage in eddy current and time transient magnetic solvers by creating a winding.
Ansys Electronics 2023 R2 - 2D Eddy Current Excitations
Ansys Electronics 2023 R2 - 2D Transient Excitations
Ohmic losses, as you mentioned, are related to the resistance of the conductors and can be calculated using Maxwell to include effects such as induced steady current losses in permanent magnets, rotor bars, or stator windings, as well as eddy losses. Core losses, on the other hand, are associated with the magnetic material of the core and include hysteresis and eddy current losses within the core material itself.
I hope this helps!
