Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › About combine different unconnected body into one part › Reply To: About combine different unconnected body into one part
October 11, 2024 at 4:30 am
philippe33
When working with unconnected blocks in Ansys Mechanical, you may have difficulty grouping them into a single part when exporting the .k input file to LS-DYNA. To solve this problem, use the grouping feature in Ansys to create a single part for all the blocks. If necessary, write a script to adjust the input automatically. Good luck, and while you're down, try playing some io games to relax!
