Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation › Reply To: Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
Vijay Narayan
I just noticed that you had already mentioned that the walls are adibatic. Is this choice accurate or should it have a non adiabatic BC ?
What is the change in pressure and temperature within the domain once the reaction starts. Could you share snippets of temp and pressure contours for CH4, H2 and CO2 driver cases (at points before and after the mass imbalance appears).
