Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Error: An error occurred when post processor attempted to load a specific result › Reply To: Error: An error occurred when post processor attempted to load a specific result
October 10, 2024 at 7:07 pm
In your case, the solution seems okay because there is a green check mark next to "Solution Information".
There are 2 warning messages:
If the result file cannot be opened, you won't be able to get the results.
I would clear the solution, set the # of steps to 1 and use all default Analysis Settings (only specify the end time), delete the results objects (Total Deformation) and solve again.
Which version of Ansys Workbench are you using?
Let us know how it goes.
Reno.
