Ansys Learning Forum Forums Discuss Simulation Photonics Resolution Bezier object Reply To: Resolution Bezier object
Guilin Sun
You can use ring object and modify the starting and stop angles to create the arc.
Bezier  https://optics.ansys.com/hc/en-us/articles/360034382234-Waveguide-Simulation-Object
https://optics.ansys.com/hc/en-us/articles/360034901673-Tips-for-creating-waveguide-bends-using-the-path-object
Once the Bezier bend chooses the order, the number of points is fixed. and the curve should be smooth.
