Ansys Learning Forum Forums Installation and Licensing Ansys Products Mass-spring system does not move properly when the spring is non-linear Reply To: Mass-spring system does not move properly when the spring is non-linear
dlooman
This is a Full (not Mode-Sup) transient, correct?  I tried it and it works for me.  I verified it by scoping a deformation result to the named selection I had to create to scope the spring to the mass.  An indirect way to check if it is moving is to create a probe for the nonlinear spring.
