Ansys Learning Forum › Forums › Discuss Simulation › Fluids › source term modification of energy equation in non-equilibrium thermal model › Reply To: source term modification of energy equation in non-equilibrium thermal model
October 10, 2024 at 1:33 pm
The problem isn't so much getting the fluid temperature as seen by the solid or vice versa but that you need to link to the two cells: so some care will be needed there.
Changing the exponent from 1 to 4 suggests radiation effects? Will this effect anything other than the front and rear (ie external surfaces) of the solid?
