Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Defining variable load for multiple time steps › Reply To: Defining variable load for multiple time steps
mohan.urs
Hey It is possible to apply a spatially varying load. But there are some limitations to the load types you can apply it with.
https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/wb_sim/ds_spatial_load.html
Check out the above link to know about supported load types and how to apply them.
Here is the help link for pressure load varying spatially in particular.
https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/wb_sim/ds_Pressure_Loads.html
You can use multiple time steps with these loads to successfully simulate loads that vary with 'x' and with 't'.
Thanks.
