Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Import Results from an excel file › Reply To: Import Results from an excel file
AR
First of all, thanks for the answers.
I have tried to do what is indicated in the link that deepak.deepak has provided.
However, it is not working properly. I have made a model to test it. The first thing I have seen is that instead of importing the 8580 rows that Excel has, it only imports the first 10.
The model on the left (original model) and the one on the right (imported results) should give the same results. However, as you can see, this is not the case. I am attaching an image that shows the normal stress on the Y axis and another one that shows the equivalent von mises stress.
What could be happening?
