Ansys Learning Forum Forums Discuss Simulation Fluids Savonius 2D simulation, Cp increasing after stall point Reply To: Savonius 2D simulation, Cp increasing after stall point
Those should be fine. The initial value is simply that if you don't run a transient model long enough you can retain regions of flow that are the initial condition and are yet to be influenced by the calculated flowfield.Â
