Ansys Learning Forum › Forums › Discuss Simulation › Electronics › I am getting different torque values for different region sizes for my machine › Reply To: I am getting different torque values for different region sizes for my machine
Ivonne Marti
Please check the field near the Region surface to be sure that the H or B field is zero. If in both cases the field is zero in this are, I would suggest to check all the settings to be sure that both models are the same. The last think you can try is to install a newer version.
I hope it helps. Ivonne
