Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Savonius 2D simulation, Cp increasing after stall point › Reply To: Savonius 2D simulation, Cp increasing after stall point
oe23s006
Under relaxation factors
PressureDensityBody forcesMomentumTKETurbulent dissipation rateTurbulent viscosity
0.2110.40.60.61
Sir I canged the underrelaxation factors in fluent from the default according to my senior’s advice (the above table is the changed values from default). Is that the problem sir? what you mentioned about the initial value retaining?
