Ansys Learning Forum Forums Discuss Simulation Electronics About magnetization direction Reply To: About magnetization direction
jayaprakash
To assign the magnetization direction in Ansys Maxwell, begin by selecting the magnet. You can then access the material definition dialogue box to specify the magnetization direction. The parameters will be adjusted according to the chosen coordinate system (CS). You can assign positive or negative values to the X, Y, or Z components for the default Cartesian coordinate system. I trust this approach will be effective for your needs in Ansys Maxwell.
