Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › result of random vibration › Reply To: result of random vibration
October 10, 2024 at 2:41 am
Hi igandiko,
’in a mess’ means the elements have a large deformation and overlap.
I find the error is result from the order of solid elements. Elements in above screenshots are second order. I change the elements into first order, the elements in d3rms file are normal, as below screenshot shows. However, result of first order is less accurate than second order.
