Ansys Learning Forum Forums Discuss Simulation Fluids Savonius 2D simulation, Cp increasing after stall point Reply To: Savonius 2D simulation, Cp increasing after stall point
oe23s006
The left image is pressure contour for tsr=0.6 (corr. to top velocity contour) and right is for tsr=1.1 (corr. to bottom velocity contour which you mentioned)
I am calculating the torque/moment sir in my case for finding the Cp.
But I see sir, so my domain is my problem. You are saying that it is causing the back pressure and interferring with the current iterations. Hence, I need to take a bigger domain?
