Ansys Learning Forum Forums Discuss Simulation LS Dyna Run LS-DYNA Using an LSTC_FILE with ANSYS License Reply To: Run LS-DYNA Using an LSTC_FILE with ANSYS License
igandiko
I would try removing LSTC_FILE and unset the env variables. To use LS-DYNA solver with Ansys license, you only need to define the below env, no need to define the LSTC_LICENSE_SERVER.
export LSTC_LICENSE=Ansys
Note that you will need any additional env you generally set for Ansys license, such as ANSYSLMD_LICENSE_FILE.
