Ansys Learning Forum Forums Discuss Simulation Fluids FLUENT UDF dynamic mesh+ MIXTURE Reply To: FLUENT UDF dynamic mesh+ MIXTURE
Mixture model and moving mesh should work fine, so chances are there's something in the set up that needs some attention. What does the UDF do, and what is moving?
Also, is there a reason you're not using 2024R2?
