Ansys Learning Forum Forums Discuss Simulation Photonics The two modes overlap the integral Reply To: The two modes overlap the integral
zhang23
Thank you very much for your response! I have tried all three methods. Unfortunately, the first two methods still result in the same issue as before, where clicking "Calculate Overlap" yields no response. However, with the third method, after adjusting the code, I obtained a result of 0.32, which seems relatively low. I'm not sure if this is due to the misalignment of the two waveguides, but I believe the misalignment should not affect this result. If you have resolved the issue I mentioned earlier, I would greatly appreciate your guidance. Thank you once again!
