Ansys Learning Forum Forums Discuss Simulation General Mechanical Contact for 2D and 3D Mixed Dimension Analysis Reply To: Contact for 2D and 3D Mixed Dimension Analysis
Kaushal Vadnere
Hi Matt,
Mixed Dimension refers to an analysis with both Solid and Surface/Line bodies grouped under a common Part. From the image you’ve shared, it seems that the surface body is not in the same component as the solid bodies. If you’re using spaceclaim, select all 3 bodies > rmb > move to new component and in properties and change share topology to ‘Group.'
