Ansys Learning Forum Forums Discuss Simulation Photonics How to tilting the model Reply To: How to tilting the model
Guilin Sun
You can use structure group to set up the geometry without tilt, and rotate the structure group as needed:
Make sure the titled geometry is what you need, by specifying correct axes and angles.
