Ansys Learning Forum Forums Discuss Simulation Fluids UDF File for heat source about solar ray tracing Reply To: UDF File for heat source about solar ray tracing
konstantinospolychronakis10
Okay thank you for the guidance! So you believe that is better option to find the solar load datasheet and load it as a parameter set to my code instead of using a macro?
