Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Exporting deformed surface › Reply To: Exporting deformed surface
Federico
you can export the xyz coordinates of your surface in ASCII format and convert these point cloud coordinates into a surface using a third party tool.
To export the surface, go to Fluent File > Export > Solution Data. Select ASCII format and the corresponding surface.
