Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Tensile Test on Laminated Composite (Pre ACP and Static Structural) › Reply To: Tensile Test on Laminated Composite (Pre ACP and Static Structural)
ashish.khemka
Did you perform the modal analysis? I see that paper has a section on modal analysis. You can perform modal analysis and check if the frequencies match for your model when compared with paper. If no then you need to check whether the frequency is higher or lower and accordingly check for stiffness of the structure (assuming that mass is same).
Ashish Khemka
