Akshay Maniyar
I understand you're encountering difficulties with the meshing process in the additive manufacturing module, specifically with the Layered Tetrahedrons method. The issues you're facing with the Sliver Triangle Height and Element Size could be related to the settings you're using for the mesh generation.Please check the below Ansys help link for more details for meshing recommendation.
Layered Tetrahedrons Method Control (ansys.com)
Thanks,
Akshay Maniyar
