Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Particle count using particle ID › Reply To: Particle count using particle ID
October 7, 2024 at 4:54 pm
I’m not sure what you mean by this. I ran the simulation using 4 or 6 processor cores (not sure exactly how many processors I used).
When I run it with 6 processors I still see that the particle ID’s repeat for approximately 4 times in the text file. Do you think I must only count one particle ID once rather than take the sum of all these id’s?
This is what I see when I go to parallel> network> bandwidth
