Ansys Learning Forum › Forums › Discuss Simulation › Electronics › When setting up the HFSS solution model, if there is no terminal … › Reply To: When setting up the HFSS solution model, if there is no terminal …
Aymen Mzoughi
You can use the HFSS driven terminal solution type but you neeed to define ports first:
https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/Electronics/v242/en/Subsystems/HFSS/HFSS.htm%23../Subsystems/An%20Introduction%20to%20HFSS/Content/AssigningDrivenTerminalSolutionExcitationsintheGUI.htm?TocPath=An%2520Introduction%2520to%2520HFSS%257CHFSS%2520Modeling%2520GUI%2520Basics%257C_____7
