Chris Quan
To define spring elements, you need to use Explicit Dynamica system and insert Spring Elements under Connections. See the 1st screen snapshot below.
Then you can link the Explicit Dynamics system to Autodyn Component system, update both Setup cell of Explicit Dynamics and Autodyn Component systems to transfer the spring elements. See the 2nd screen snapshot below.
