Ansys Learning Forum Forums Discuss Simulation General Mechanical ANSYS Additive Suite Thermal Profile Reply To: ANSYS Additive Suite Thermal Profile
John Doyle
In WB-Additive, it is possible to extract the transient temperature results at a specific nodal location. You need to first enable the export of nodal data in Mechanical GUI by going to File => Options => Export and setting "Include Node Location" to "Yes".  Additionally, after running the simulation, create a named selection and scope result to the strategic node of interest.  Then, with this Named Selection result highlighted in the Solution Branch, click on the top left corner of the Tabular Data (next to the graph), RMB and click on 'Select All' and then click on  'Export'.    You can choose to send this result set to either an excel or txt file.  Â
