Ansys Learning Forum Forums Discuss Simulation Fluids Operation would result in non-manifold bodies Reply To: Operation would result in non-manifold bodies
Non-manifold tends to trigger when you have surface-surface contact with zero area. As an example where a cylinder contacts a flat surface: eg the bottom of the tyre. If you flatten the bottom of the tyre a bit (highly precise engineering dimension unit) does that help?
