Ansys Learning Forum Forums Discuss Simulation Electronics Induced voltage value for ferrite vs neodymium magnet for same ipmsm Reply To: Induced voltage value for ferrite vs neodymium magnet for same ipmsm
Timos
Hello, it seems like there might be an issue with the simulation setup or the material properties used in the simulation. Could you please check if the Magnitude of the Magnetic Field is the same inside the material definition?
