Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Spray water particles not injected › Reply To: Spray water particles not injected
October 4, 2024 at 8:29 pm
I found the diameter option in particle track panel, now my solution doesn’t converged. Error message in below, do you know what could be the reason? look like something to do with my temperature setting.
============================================================================Â
iter continuity x-velocity y-velocity z-velocity   energy      k    omega   time/iter
 1040 2.3827e-03 1.2309e-07 1.3347e-07 2.6021e-07 1.6748e+293 3.8479e-06 6.8937e-07 0:00:21  20
    Stabilizing temperature to enhance linear solver robustness.
    Stabilizing temperature using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: temperatureFilm time = 5.210000e-02 with timestep = 1.00e-04, (max_cfl: 6.705262e+00)
Film time = 5.220000e-02 with timestep = 1.00e-04, (max_cfl: 3.464841e+00)
Film time = 5.230000e-02 with timestep = 1.00e-04, (max_cfl: 3.045373e+00)
Film time = 5.240000e-02 with timestep = 1.00e-04, (max_cfl: 5.991012e+00)
Film time = 5.250000e-02 with timestep = 1.00e-04, (max_cfl: 6.446741e+00)
Film time = 5.260000e-02 with timestep = 1.00e-04, (max_cfl: 1.304315e+01)
Film time = 5.270000e-02 with timestep = 1.00e-04, (max_cfl: 1.205507e+01)
Film time = 5.280000e-02 with timestep = 1.00e-04, (max_cfl: 3.353779e+00)
Film time = 5.290000e-02 with timestep = 1.00e-04, (max_cfl: 3.320096e+00)
Film time = 5.300000e-02 with timestep = 1.00e-04, (max_cfl: 3.241072e+00)
 Artificial walls on 97 faces (0.4% area) of pressure-outlet 20 to prevent fluid from flowing into the boundary.
Error at host: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error at Node 1: floating point exception
Error: floating point exception
Error Object: #f
