Ansys Learning Forum Forums Discuss Simulation Fluids Spray water particles not injected Reply To: Spray water particles not injected
andrewl
No exhale simulated, I was just simulating inhalation and particle injection. Outlet boundary was set to "trap" so even pass the side of the nose it should be trapped and shown somewhere in the geometry.
Is "scale" in particle tracks panel same as what you said the display diameter?
