Ansys Learning Forum › Forums › Discuss Simulation › Materials › CHEMKIN: Chemical reaction kinetics parameter needed › Reply To: CHEMKIN: Chemical reaction kinetics parameter needed
SVV
You can find some of the mechanism files in the Ansys Installation directory under reaction folder. If you find the mechanism you are working on, you can make use of it. If not, you will have to find the rate parameters from the research papers on similar topic.
The below link will be helpful for you: 3.3.2. Gas-Phase Chemistry (ansys.com)
