Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Errors with multi-connected bodies using AQWA › Reply To: Errors with multi-connected bodies using AQWA
Hi! It sounds like you're facing issues with your floating pontoon models and mooring lines. Here are a few suggestions to troubleshoot the error:
Check Constraints: Ensure all joints are properly defined and compatible with the linear elastic cables you're using.
Review Connections: Confirm that all connections between the pontoon and mooring lines are correctly set up.
Joint Settings: Double-check the settings for the ball and socket joint. Make sure it’s configured to allow the necessary degrees of freedom.
Model Scale: Ensure the scale of your model is appropriate; sometimes, very small or large scales can lead to unexpected behavior.
Software Documentation: Refer to the software’s documentation or forums for specific guidance on the error message you’re receiving.
If the problem persists, providing the specific error text could help diagnose the issue further. Good luck!
