Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Spray water particles not injected › Reply To: Spray water particles not injected
Ah, yes. In the Particle Tracks panel you can set a display diameter - that tends to help. For info 1micron particles will typically follow the flow, miss the sides in the nose and be exhaled on the next breath. You may want to do some reading on drug & carrier particle sizes, or I do if the practice has moved on in the last few years.
