Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › SPG for failure simulation › Reply To: SPG for failure simulation
Ram Gopisetti
Hi Lantonini,
Let's first check the material model, I am assuming MAT_077_O here, if yes we do support this material model but it's not fully validated with FEA. So expect some differences in behavior and results.
It is recommended to use *MAT_ADD_DAMAGE_GISSMO rather than *MAT_ADD_EROSION as SPG only supports *MAT_ADD_DAMAGE_GISSMO with R15. However, MAT_ADD_EROSION can turn on GISSMOfrom R14.1 but after R15 it has to be correctly defined to be MAT_ADD_GISSMO
It is also recommended to use dtye.ne.0, GISSMO damage model to work. The failure process is not controlled by SPG. The failure phenomena in SPG part is the result of particle deformation. Additionally, you need to set IDAM =0 and set FS to a large value along with MAT_ADD_GISSMO to drive failure based on the failure card or switch off this card and only set FS and Stretch values
So, please check by either disability one option and post the results here to know what's happening and please use R15 and up for consistency.
Cheers, Ram
