Ansys Learning Forum Forums Discuss Simulation General Mechanical the simulation results do not match the defined material curves Reply To: the simulation results do not match the defined material curves
Armin
Thanks. I assume you're plotting the equivalent stress versus strain. Do you see the same behavior in all regions or only in the element where stress is the highest? If so, I suggest that you try refining the mesh in that area to see if the predictions improve.
